change appearance of push button
aka
do you know how to change the shape of the green part of a push button?
i'm using Labview 6.0.3.
thanks
1. select the push button
2. in Edit menu select; "Customize control..."
3. while in control editor, locate and press the button with a wrench (in the Toolbar)
4. use the "parts window" to access the different parts that you want to replace or edit.
Good luck!
/J
Good luck!
/J
i tried your suggestion and what happens is that you still cannot replace or edit the green part with a circle for example, or even rotate it. other suggestions?
thanks
thanks
Right click on the parts you want to change and select import picture.
This has to be done for both states (On and Off), i.e. swith boolean state between edits.
Attached is a control where I replaced the green part with a triangle.
post-5958-1169746269.png?width=400
Download File:post-5958-1169745969.ctl
I'm sorry I don't have LabVIEW 6.03 available so the control is in LV 7.1.1
/J
