Combo Box bugs (2)
Mellberg
Hi Folks,
Just want to report two LV-bugs I found. The bugs are reported to NI.
First, if a combo box is set to 'allow undefined strings', you can't write 'ABBA' if 'abba' already exists among the 'strings []', i.e. a pull down-menu item.
Second, if a combo box string-item (one of the pull down-menu items) contains a string that is 276 chars or more in length, this can either cause LV to pop up a 'crash' dialog or crash hard without any dialog.
These two bugs exists from, at least 7.0 to 8.2, as far as I know.
//Mellberg
  • 2 months later...
  • 3 weeks later...
One other strange thing I just found out:
It's not possible to enter a comma in a combo box???
Is there a good reason for this??
VDB
QUOTE(VDB @ Apr 20 2007, 04:19 PM)
Is this in 8.0?
I just tried it in versions both before and after 8.0 and I have no problem in typing a comma into a combo box.
Can you upload an example VI with detailed instructions?
QUOTE(yen @ Apr 21 2007, 09:20 PM)
Is this in 8.0?
It's 8.2. Start LabVIEW, new VI, create a combobox (doesn't matter if modern, classic or system) and try to type a comma.
Pasting a comma works. Maybe it's because of the German Windows...
VDB
QUOTE(VDB @ Apr 23 2007, 08:56 AM)
VDB
I can reproduce this on WinXP (English).
Defining the list of allowable values works with commas, but entering commas into the Combo box don't.
I think you should report this to NI as a separate bug, and maybe start a new bug thread here at LAVA.
/J
QUOTE(VDB @ Apr 23 2007, 09:56 AM)
Works fine in a version which is above 8.0, but is not 8.2 (or 8.2.1), so either this was fixed, or it could be an issue with locale settings. You could try setting your OS settings (Control Panel>>Regional and Language Options) to use the period instead of the comma and see if that changes it.
QUOTE(yen @ Apr 23 2007, 09:57 PM)
The behavior stays the same, I guess it's a bug..
VDB
  • 1 month later...
