Application Initialization ... how best to do it
I have created an application that will become an executeable. I currently have 8 sets of values that I would like to put in an init file, and loaded each time the exe runs. I would like it to be a textfile, so it could easily be edited by the user, but that is not a requirement at this time. The main thing is that the user can change any of these values and have them restored after a restart.
I currently have the following to init:
A small tab delimited text file
Two path statements
A small integer array
A small floating point array
A boolean
Two single integers
I would like to know what is commonly done for init files, and how best to do this one. My ideas so far are messy. :-)
I can change the application to suit, no restrictions there that I know of. It is a custom monitor and logging app.
I did a search of this part of the forum, but did not see anything pertinent. This seems like the place it should be.?
Fred
BTW, these VIs are located in the OpenG package called oglib_variantconfig, which can be downloaded and installed with VIPM.
If you just have a few simple items and haven't installed the openG stuff, the NI ini functions will work fine as well. If you're already running in the openG environment, it is probably more flexible, however...
Thanks for all the suggestions! :-)
I would like to get the functions that LTR provided, but they are closed for business... sigh
They were in LTR Volume 8 Issue 3 or LTR CDROM Lib of Back Issues.
Anyone know how I could get just the VIs?
Best regards,
fbrandeber@elmwi.com
