alameer Posted February 19, 2007 Report Share Posted February 19, 2007 hi there is problem with labview 8 i cant configuration in front panle or bolck digram after save me work and close it . what is the problem here ? Quote Link to comment
Jeff Plotzke Posted February 19, 2007 Report Share Posted February 19, 2007 QUOTE(alameer @ Feb 18 2007, 02:03 PM) there is problem with labview 8 i cant configuration in front panle or bolck digram after save me work and close it . what is the problem here ? Alameer, what problem are you facing? Are you getting an error message? What error message? We need to know much more information before we can help you. Did you make your VI read-only? Quote Link to comment
alameer Posted February 19, 2007 Author Report Share Posted February 19, 2007 thank U Mr.jeff the description of problem Quote Link to comment
Jeff Plotzke Posted February 19, 2007 Report Share Posted February 19, 2007 It looks like your VI is not in edit mode. Go to Operate > Change to Edit Mode (or press Ctrl+M) to change it. You may have the option turned on which opens a read-only VI in run mode automatically (which is probably a good idea to have to remind you that you can't save the VI). To check if you have this enabled, Tools > Options > Environment > Treat read-only VIs as locked Quote Link to comment
alameer Posted February 19, 2007 Author Report Share Posted February 19, 2007 thank u Mr jeff Quote Link to comment
