Application instance change in 8.2
Salut.
I have been using an home made deploying tool since LabVIEW 6.x.
Somewhere along the deployment, the tool does a save as on the source code of the deployed software. The deployment tool and the deployment software are both link to a library of VIs.
In LV6 and 7, i had to rename all the VIs used by the deployment tool in order for the save as to work because of the unique name in memory rules of those versions.
In LV8 i did not have to do this because my deployment tool was running in the "NI.LV.Dialog" application instance and the save as was working.
Now in LV8.2, it seems that it does not work anymore, i get an error stating that the VI cannot be saved in the current state. And i get this error on the shared VIs.
Is there a work around, or will i have to revert to doing a mass duplicate save as for the deployment tool VIs?
See this post for more info. I recommend considering using OpenG Builder to do what you are after, if it will do what you want. We're still polishing up some improvements for LabVIEW 8.2 compatiblity. If you would like a preview release, let me know.
Thanks,
-Jim
