gustav Posted February 22, 2007 Report Posted February 22, 2007 I'm running a counter task for pulse generation, using an external signal as a source for ticks. I'm wondering if it's possible to switch the input terminal for the ticks while the task is running? This means I would have two sources of pulses connected to two different pins on my NI6602 card, and while the pulse generation task is running I want to be able to switch from which pin it gets the ticks. When I try to do this I get an error, so it appears to me it is not possible. However I thought I should check with the expert before ruling out the possibility, or perhaps someone could tell me another way to accomplish what I need . Any answers would be apreciated. /Gustav Quote
Neville D Posted February 22, 2007 Report Posted February 22, 2007 QUOTE(gustav @ Feb 21 2007, 06:50 AM) I'm running a counter task for pulse generation, using an external signal as a source for ticks. I'm wondering if it's possible to switch the input terminal for the ticks while the task is running?This means I would have two sources of pulses connected to two different pins on my NI6602 card, and while the pulse generation task is running I want to be able to switch from which pin it gets the ticks. When I try to do this I get an error, so it appears to me it is not possible. However I thought I should check with the expert before ruling out the possibility, or perhaps someone could tell me another way to accomplish what I need . Any answers would be apreciated. /Gustav Your right.. once the task is started, you can't switch pins mid-stride. Neville. Quote
gustav Posted February 23, 2007 Author Report Posted February 23, 2007 QUOTE(Neville D @ Feb 21 2007, 06:34 PM) Your right.. once the task is started, you can't switch pins mid-stride.Neville. Thanks for confirming my suspicisons ! Will have to think of another solution then. Quote
