DAQcard 6062E between channel delay
s_yakov
I experienced a between-channel delay when acquire multichannel analog data with my PCMCIA DAQCard-6062E.
I can not find the switch-delay value in the DAQCard-6062E specification.
Where can I find a specification for the switch-delay value? Does this value controllable by NIDAQ software?
This switch delay should be very small. What is the delay that you are seeing?
QUOTE(s_yakov @ Feb 27 2007, 04:29 PM)
QUOTE(sonic_raajit @ Feb 28 2007, 05:03 AM)
As I measured, the switch delay is 4us. It is not very small for my application. I have to arrange a compensation of this delays in my software. What I want to know is exact value of the switch delay. It must be specified in DAQCard-6062E hardware manual, but I can not find it in the manual. It would be great, if NI illuminate the switch delay value for me.
Thanks in advance.
Well the 6062E is a 500 kS/s device eg. 2 us. It will be quite hard to say anything about a 4 us signal.
To get exactly the same time, you'll need a simultaneaous sampling device (quite expensive)
Ton
