s_yakov Posted February 28, 2007 Report Share Posted February 28, 2007 I experienced a between-channel delay when acquire multichannel analog data with my PCMCIA DAQCard-6062E. I can not find the switch-delay value in the DAQCard-6062E specification. Where can I find a specification for the switch-delay value? Does this value controllable by NIDAQ software? Quote Link to comment
sonic_raajit Posted March 1, 2007 Report Share Posted March 1, 2007 This switch delay should be very small. What is the delay that you are seeing? QUOTE(s_yakov @ Feb 27 2007, 04:29 PM) I experienced a between-channel delay when acquire multichannel analog data with my PCMCIA DAQCard-6062E.I can not find the switch-delay value in the DAQCard-6062E specification. Where can I find a specification for the switch-delay value? Does this value controllable by NIDAQ software? Quote Link to comment
French LVer Posted March 1, 2007 Report Share Posted March 1, 2007 As sonic_raajit said, settling time is very short. You must have some side-effect problem. You should consult "E Series User Manual" page 2-9 to 2-13 (Multichannel Scanning Considerations). You can find this manuel here : E Series User Manual I hope it will help you. Quote Link to comment
s_yakov Posted March 1, 2007 Author Report Share Posted March 1, 2007 QUOTE(sonic_raajit @ Feb 28 2007, 05:03 AM) This switch delay should be very small. What is the delay that you are seeing? As I measured, the switch delay is 4us. It is not very small for my application. I have to arrange a compensation of this delays in my software. What I want to know is exact value of the switch delay. It must be specified in DAQCard-6062E hardware manual, but I can not find it in the manual. It would be great, if NI illuminate the switch delay value for me. Thanks in advance. Quote Link to comment
Ton Plomp Posted March 1, 2007 Report Share Posted March 1, 2007 Well the 6062E is a 500 kS/s device eg. 2 us. It will be quite hard to say anything about a 4 us signal. To get exactly the same time, you'll need a simultaneaous sampling device (quite expensive) Ton Quote Link to comment
