siallid Posted March 3, 2007 Report Share Posted March 3, 2007 Hi, Can I get output from PCI-6023E , because I have a DAQ system consists of: PCI-6023E card SCXI-1001 chassis SCXI-1803 Tblock SCXI-1100 Multiplexing amplifier I use a code written with labview 6.1 to measure and log signals. but if I want to have an output signal for control or any othe purpose what hardware modification I need? Thanks, :question: Quote Link to comment
LAVA 1.0 Content Posted March 3, 2007 Report Share Posted March 3, 2007 QUOTE(siallid @ Mar 2 2007, 07:41 AM) Hi, Can I get output from PCI-6023E , because I have a DAQ system consists of: PCI-6023E card SCXI-1001 chassis SCXI-1803 Tblock SCXI-1100 Multiplexing amplifier I use a code written with labview 6.1 to measure and log signals. but if I want to have an output signal for control or any othe purpose what hardware modification I need? Thanks, :question: You should not post everything twice... hello siallid, this is not the NI-Forum, so you should ask NI or just have a look at http://www.ni.com and search for your hardware... However PCI-6023E => No analog Output... So you need diffrent HW... you could use a USB-Module from NI with an Analog Output. I use the USB-6259 (32 Analog Inputs, 4 Analog Outputs) or another PCI card... => http://www.ni.com Quote Link to comment
