Sally1983 Posted March 6, 2007 Report Posted March 6, 2007 Dear all, This is new user , I first want to thank you for that great forum , hope I can also help the other members ,I have question wish I can find a solution in your great forum : I want to extract all ponts of sin wave ; I mean I want to take it point by point ..then took those points and display !! I have tried that its changing a lot cze its function of time !! any help plzzz Quote
Yair Posted March 6, 2007 Report Posted March 6, 2007 You might wish to start by looking up some LabVIEW tutorials and learning the basic of LV. After that you might want to check out the example finder (Help>Find Examples) and maybe the analysis VIs. If after doing all that you're still having problems, you should post more details about your source data and your desired target data, as well as any code you have written. You might also want to check out the NI forums, which have a much larger user base and which are more appropriate for this level of questions. Quote
