a call for DAQmx guidance
Hi all,
We have different ways to create DAQmx tasks :
- in MAX,
- in the project (*.lvproj),
- or directly in the LV code.
I use to do it in the LV code and it was working fine. For a new project I created my DAQmx tasks in the project because I thought that was the right way to do it... I now doubt and need some help.
Indeed, if I run the LabVIEW code it works as expected, and when I create an exe I get an error that says'm refering to a task that does not exist.
Why is that ? Is there some settings to add in the build specs ?
Thanks for any help.
PS : I know I could create my tasks in MAX and would then have to export the MAX config (*.nce), but I'd like to have everything in the exe, just like when the tasks are created in the LV code.
