send values to another VI
Open_AddDev_Run_Read@ controls via ActiveX a simulation from CANape. This simulation uses event structure to trigger a read or write process on value change (it cannot be run if you do not have CANape installed on your computer - but this is not important).
With WriteReadCANapeVI I change the value of the controls in the previous VI, but the event structure does not react on value change in this case.
How this works? Any idea how I can fix this?
Thank you.
