State machine problems
I have written some Verilog code for a watchdog timer, but on compliation all the states are synthesised away, so that when simulated it gets stuck in state 0 without doing any of the stuff in that state !
If anyone is willing to help here's the code :
//iPAM controller watchdog timer
//N Roberts
//22/03/07
module iPAMWDT (iclock, sys_clk, error);
input iclock; //iPAM clock in 250Hz
input sys_clk; //System clock 50MHz
output error; //Status of iclock for
//reset module
reg error;
reg [2:0] state; //State variable
reg count; //Counter variable
always @ (posedge sys_clk)
case (state)
//Initialisation state
3'b000: begin
count = 10;
error = 1'b1;
state = 3'b001;
end
//State to check pulse width of
//high part of 'iclock'
3'b001: begin
state = 3'b001;
//Count decrement during
//high part of cycle
if (iclock & (count > 0))
count = count - 1;
//Check for low part of cycle
if ((!iclock) & (count > 0))
begin
count = 10;
state = 3'b010;
end
//Check for timeout
if (count == 0)
state = 3'b100;
end
//low part of 'iclock'
3'b010: begin
state = 3'b010;
//low part of cycle
count = count - 1;
//Check for high part of cycle
if ((iclock) & (count > 0))
begin
count = 10;
state = 3'b001;
end
//Check for timeout
if (count == 0)
state = 3'b100;
end
//Error state remains in this state
//until a reset occures
3'b100: begin
state = 3'b100;
error = 1'b0;
//stay here if an error
end
default:
begin
state = 3'b000;
end
endcase
endmodule
Any suggestion greatfully received. I am using Quartus 5.0.
