serial port
Hello ...
IN LabView 8
I need to Know how to Out the data form LabView On the Serial Port...
if there's an example to read or if anybody can direct me i'd be Greatful
Thnx in advance
Sherif Farouk,
Interaction with the serial port is done through the VISA API. If you open the example finder (Help>Find Examples) you should be able to find as many examples as you want. You should probably go through some tutorials first and try searching online before posting.
