USB-6008 Multiple I/P problem
Hello everyone,
I'm working on a project where i'm using the USB-6008 card for data acquisition. So far i've been using two digital output ports, an analog input and an analog output. Things worked great, but as a further enhancement to the project, i'm supposed to recieve another signal through an analog input, when i developed the VI that can do this, an error message showed up upon running the system telling me that the input port has been reserved!!!
I'm sure i have correctly assigned different ports for each 'DAQ Assistant Box'. Is there any other way to build daq VI's other than DAQ Assistant, or is there a way to solve this problem.
P.S I'm not sure if this is the right forum to post this topic, but i'm new and i think this was the most relevant forum i found. Please excuse me for this. :)
Thanks in advance everyone. :)
QUOTE(fuzzycontrolfreak @ Mar 29 2007, 05:40 PM)
  Quote
Hi Fuzzycontrolfreak,
DAQ assistant is only good for short tests/simple acquisitions
If you want to seriously use DAQ you have to start use lower level DAQmx VIs. There are a lot of examples in the Example finder.
Have a look there and you will most likely find what you need.
Ton
Sounds like you have two DAQ Assistant nodes, each configured to read a different channel. Yeah, you'll have problems.
You need to configure both AI channels in one DAQ Assistant, unless you need different configurations (sampling rate, triggering, etc), then you'll need to work with the DAQmx VIs.
-James
  • 1 year later...
Your problem makes me think of the different settings: Differtial or RSI (? Don't know exact name.)
When you put it to differential, 2 inputs are used as input one.
If you want to initialise the second input, without knowing it's already used, labview shows: already used.
