Installer wrapping NI-DAQ and MAX config
Hello,
I want to distribute a LV 7.0 Express application for a customer.
It uses a PCI-6036E card for Data Acquisition together with MAX 3.0.2.3005
on
some computers and MAX 3.2 on others.
All target computers uses Windows 2000.
I need to install the customer application, together with LabVIEW Runtime,
NI-DAQ (supporting Traditional DAQ), the PCI-6036E drivers and import
Traditional DAQ virtual Channels in MAX. The customer want the installation
to
be automatic, so he would like a single installer wrapping all those
functions.
I looked at many tutorial and stuff on www.ni.com and tried some tricks,
but
doesn't seem to work well.
The last installer I manage to build (with LabVIEW 7.1 Development Build
Application and Shared Library) could :
1) Install the customer application
2) Install LabVIEW Run Time
3) Launch the NI-DAQ 7.4 installer (but the installer couldn't function :
either I had a Windows error telling me that the installer couldn't load
everything or either It started sucessfully, but the progress bar was
coming
back and forth, with no progression...but no particular failure)
My last application build is attached to this message. I used a batch file
to
launch the NI-DAQ installer. I included all NI-DAQ 7.4 installer files in
/drivers directory under the main installer directory.
Is it possible to build a complete installer wrapping al of those function
with
LabVIEW 7.1. Can I define Traditional DAQ Virtual Channel with MAX 4.2 on
my
computer even if I don't have the proper hardware and export it to target
computers with the real thing (MAX 3.0.2 or 3.2 with the real PCI device)!
And
can I export those channels automatically within the installer itself.
Thank you,
Sebastien Gelinas
Don't know if this will help, but if you can upgrade to LV 8x, you can automatically add NI components to the installer for your application like MAX, DAQmx etc.
will save you the hassle of trying to build a global installer with all these components yourself. And why do you have two different versions of MAX? Just upgrade one to match the other.
Also, if you use DAQmx you have the ability to programmatically define channels, so you wouldn't need the virtual channels of the old-style DAQ.
You can also convert old-style virtual channels to equivalent objects in DAQmx called "global chans" or something like that (in NI-MAX).
Neville.
