george seifert Posted April 11, 2007 Report Share Posted April 11, 2007 I know this was working with LV8.2. I just downloaded 8.2.1 and it's not working. I've enclosed a simplified example. I get error -2513 when I run it. Possible reason(s):LabVIEW: LabVIEW does not support properties of the specified data type. First could someone who has 8.2 please confirm that it doesn't give an error? If I delete array elements 0 and 1 from the "data" control it works. If delete any other combination of elements I get the error. I tried deleting all the elements and created some new waveform elements without attributes and it worked. I can't see anything wrong with the existing attributes. Can anyone see what could be wrong? Thanks, George Quote Link to comment
Herbert Posted April 12, 2007 Report Share Posted April 12, 2007 George, I have tried your VI and I can reproduce the problem. The root cause is that the data type of the "NI_ChannelName" property on some of your waveforms is "tag" instead of "string". My first thought would be that the change in data types was introduced by a new driver version. Did you recently update your drivers? The issue is filed as CAR# 489IR4WJ. There is a workaround, which is converting the property type from tag to string (that's a perfectly valid conversion). It's not nice, but at least it is simple. http://forums.lavag.org/index.php?act=attach&type=post&id=5459 Sorry for the inconvenience, Herbert Quote Link to comment
george seifert Posted April 12, 2007 Author Report Share Posted April 12, 2007 QUOTE(Herbert @ Apr 10 2007, 08:29 PM) George,I have tried your VI and I can reproduce the problem. The root cause is that the data type of the "NI_ChannelName" property on some of your waveforms is "tag" instead of "string". My first thought would be that the change in data types was introduced by a new driver version. Did you recently update your drivers? Sorry for the inconvenience, Herbert Thanks for the confirmation and the workaround. Yesterday I upgraged to LV 8.2.1 and DAQmx 8.5. George I found another workaround. I attached my fix. I was taking the AI.CustomScaleName from the DAQmx Channel node and feeding it directly to the Set Attributes VI. I inserted the convert variant to string and it fixed the problem. http://forums.lavag.org/index.php?act=attach&type=post&id=5463''>http://forums.lavag.org/index.php?act=attach&type=post&id=5463'>http://forums.lavag.org/index.php?act=attach&type=post&id=5463 George Quote Link to comment
Herbert Posted April 12, 2007 Report Share Posted April 12, 2007 QUOTE(george seifert @ Apr 11 2007, 06:28 AM) I was taking the AI.CustomScaleName from the DAQmx Channel node and feeding it directly to the Set Attributes VI. I see. I thought you had taken the whole waveform from a DAQmx VI, in which case it should have been a string. We normally coerce tags to strings in most LabVIEW functions, but if they are "hiding" in variant/waveform attributes, that doesn't happen automatically. Need to add that in TDMS Write. Thanks, Herbert Quote Link to comment
