Jim Kring Posted April 15, 2007 Report Posted April 15, 2007 I've just posted an article called Supporting Multiple Versions of a File Format. Quote
jaegen Posted April 18, 2007 Report Posted April 18, 2007 Great article! If only you'd written it 3 years ago ... QUOTE ...the snapshots should not be connected to any type definitions, since a snapshot should never be changed, once it is declared to be an official version.Note: The tricky part with this step is disconnecting a control from all type definitions, recursively. But, there are tools that can easily be made to automate this. Have you (or anyone else) made such a tool??? Jaegen Quote
Jim Kring Posted April 18, 2007 Author Report Posted April 18, 2007 QUOTE(jaegen @ Apr 16 2007, 03:43 PM) Great article! If only you'd written it 3 years ago ... Have you (or anyone else) made such a tool??? Jaegen Jaegen, Thanks for the feedback. I hope the article is not too late to be of good use to you I have added a downloadable example as an attachement to the article, http://thinkinging.com/2007/04/14/supporting-multiple-versions-of-a-file-format/' target="_blank">here. Thank you, -Jim Quote
