ControlEngineer Posted April 18, 2007 Report Posted April 18, 2007 Hello all , I need your help for solving my problem I used the "Square Waveform.vi" tool to generate a square wave and have ability to control its duty cycle Every thing is ok , but i want to ask how i can output this signal using 6024E-DAQ so that i can use it to control a servo motor .. i know it is very easy to use analog output , but i want to use a digital one .. is this possible ? how? i tried to use "analog to digital" to convert the signal into digital form befor taking it on the output port ,, but useless attempt Please , any one can help thank you any way yours ,,, Quote
Neville D Posted April 18, 2007 Report Posted April 18, 2007 QUOTE(ControlEngineer @ Apr 17 2007, 02:27 PM) i know it is very easy to use analog output , but i want to use a digital one .. is this possible ? how? Whats the problem with using an analog output? Neville. Quote
James N Posted April 19, 2007 Report Posted April 19, 2007 Search the Help>Find Examples in LabVIEW. Check under "Hardware Input and Output". Look for an example like "Gen Dig Pulse Train-Continuous.vi" There plenty of examples that do almost exactly what you're looking for.. if not exactly! -James FYI: "LAVA > Resources > Bug Lists > LabVIEW 8 Buglist" was probably not the right forum for this question.. Quote
ControlEngineer Posted April 19, 2007 Author Report Posted April 19, 2007 Hello Thank you Neville , i dont want to use analog outputs because i dont have enough channels to control more than two motors at the same moment Quote
Neville D Posted April 19, 2007 Report Posted April 19, 2007 QUOTE(ControlEngineer @ Apr 17 2007, 10:11 PM) Hello Thank you Neville , i dont want to use analog outputs because i dont have enough channels to control more than two motors at the same moment AAAhhh..!!! You should have stated this earlier. I suspect you will be able to control AT MOST 2 motors with a single DAQ card. The reason is that each card has only 1 FIFO and if you are dynamically going to be changing the frequency and or the Output value using hardware timed IO, you will be able to do it for at most one output channel. I think you will need to use counters for the pwm and not the digital outputs. You are limited to two counters and may even need both for one pwm. Sorry I haven't used DAQmx in a while, but its going to be difficult to control a whole bunch of pwms with a single DAQ card. Just build a little "Analog Voltage in->PWM out" circuit and control via the analog output. Neville. Quote
