asharma Posted April 23, 2007 Report Posted April 23, 2007 I had previously posted my querry but as per suggestions i uploading new vi. To be precise what is required in this project is to create a counter and count the no of times an event occurs(which in this case is toggling of switch). This vi is simulation based because i dont have daq card at my home.(think of a daq instead of simulated signal) i would be grateful if anyone would help making a vi based on the objetive. The hardware model shows three holes and each has a bulb attached.When hardware switch is pressed a counter must start and count1=1,now if switch2 is pressed count2=1.again is switch1 is pressed count1=2, this process should go on. if anyone could build a vi with reference to above requirements using projectsimulate.vi as the base???? Quote
crelf Posted April 23, 2007 Report Posted April 23, 2007 QUOTE(asharma @ Apr 23 2007, 02:26 AM) I had previously posted my querry but as per suggestions i uploading new vi... Glad to hear you're trying, but please don't post a new thread - go back to the original thread and create a new post there (just click on "reply" at the bottom). Quote
