Karlos Posted April 24, 2007 Report Posted April 24, 2007 How to made a front panel windows, always on top, and how to disable all the short cuts in some key's for example the context help when i press F1 Quote
Rolf Kalbermatter Posted May 16, 2007 Report Posted May 16, 2007 QUOTE(Karlos @ Apr 23 2007, 04:32 PM) Quote How to made a front panel windows, always on top, and how to disable all the short cuts in some key's for example the context help when i press F1 What version of LabVIEW? The always on top is called floating and is something that has changed about from 7.x to 8.x. If you use 8.2 then it is simply a property of the VI Frontpanel class, called "Behaviour" and one of its values is Floating or Floating w/ Autom-Hide. By removing the menu you should be able to disable the menu short cuts at runtime. Rolf Kalbermatter Quote
