Aristos Queue Posted July 1, 2009 Report Posted July 1, 2009 I was typing a list of items. I did A) blah and then I tried to do the second item: more blah. You can see the result. If you type B ) without the space between those two, it turns into the sunglasses smilie. Is there any way that we can disable that particular typing shortcut? 1
Gary Rubin Posted July 1, 2009 Report Posted July 1, 2009 Maybe it's trying to tell you that you ought to jazz your lists up a bit. After all, word lets you customize the bullet symbol for bulleted lists... Your lists could be: More lively More interesting More distracting... Gary
Jeff Plotzke Posted July 1, 2009 Report Posted July 1, 2009 You can see the result. If you type B ) without the space between those two, it turns into the sunglasses smilie. Is there any way that we can disable that particular typing shortcut? Because the second item in a list is always the coolest! I just turned off the B) shortcut for it. Lettered lists should work normal now 2
