dynamic insert of icons or images in Table
if you want to use icons, you have to use a listbox, a multicolum listbox, a tree menu, etc. Tables do not support icons.
You can edit the icon set of eg. a tree menu with the property nodes. First you have to set the "icon array", and the best method is to set the icon array once, providing all icons, you want to use. After that you can set the icon of each row with the property node programmatically, you just have to set the index of the used icon.
