Phil Duncan Posted May 1, 2007 Report Share Posted May 1, 2007 G'Day all. I would like to plot some data on a compass rose type display and be able to rotate the data along with the compass rose. I guess the closest thing I can think of to describe it is a radar image that has bearing markings and can rotate about it's centre. Like the image attached. Currently I am playing with XY plots (rotating data blobs) and I can programatically rotate a simple gauge indicator, but I need to incorporate the data "into" the gauge (without any needles) and rotate the lot. Any ideas? Thanks in advance for your help. Cheers & Beers :thumbup: :beer: Quote Link to comment
crelf Posted May 1, 2007 Report Share Posted May 1, 2007 QUOTE(Phil Duncan @ Apr 30 2007, 06:28 PM) I would like to plot some data on a compass rose type display and be able to rotate the data along with the compass rose. Hmmm - that's quite a challenge. You might need to impliment this from scratch using a picture control... Quote Link to comment
PJM_labview Posted May 1, 2007 Report Share Posted May 1, 2007 I think you could do that using a standard XY graph. Since LV 8.0, there are 3 additionals image plot that you could use to draw your compass picture. So here how it goes: -Rotate & Plot your XY data -Rotate & Plot your Image on the PlotImage Front (you might have to use a mask to get some transparency [see through]) Note: This will require some work but this is doable Note2: Search the NI Forum for routines to rotate images PJM Quote Link to comment
Phil Duncan Posted May 2, 2007 Author Report Share Posted May 2, 2007 Thanks for the prompt replies. I had a look at the forums and found quite a few very useful VI's for rotating picture control images. After playing with it a little more I have managed to nut out a solution I think is a little quicker than all the pixmap calculations. I can plot data on an XY graph and rotate it quite easily. For the compass rose, I ended up making the FG and BG of a gauge indicator transparent (as well as the needle), changed the tick marks and numeric values to yellow, and overlaid it on the XY graph. rotating the gauge is then done by simply changing the Scale.ScalePosition.Start value programatically. It now rotates with the data in the XY graph and the user can not tell they are two separate entities :thumbup: . Here is a pic of the display as configured. Cheers & Beers :thumbup: :beer: Quote Link to comment
Michael Aivaliotis Posted May 2, 2007 Report Share Posted May 2, 2007 Now this is a good candidate for an XControl if I ever saw one. Quote Link to comment
crelf Posted May 2, 2007 Report Share Posted May 2, 2007 QUOTE(Michael_Aivaliotis @ May 1 2007, 12:30 PM) Now this is a good candidate for an XControl if I ever saw one. Absolutely - and also a great candidate for OpenG! Quote Link to comment
