[LV 8.2.1] TDMS Get Property Bugs
The attached VIs demonstrate 2 bugs with the TDMS Get Property primitive
1) Attempting to read properties that do not exist from a TDMS file return whatever was last read from the TDMS get property primitive (from whatever was the last TDMS file the TDMS get Property was invoked on). This is VERY confusing.
Severity: High
Work Around: Sort of one: Generate an explicit error with the property you are attempting to read prior you read them (see attached example).
2) Attempting to invoke TDMS get Property with a blank property name input on a TDMS file does crash LV
Severity: Medium
Work around: don't read blank property name
To see both these bug in action, extract the attached zip in a folder and run "demo bug.vi" and use the provided TDMS files "No Header Info.tdms" and "Has Header Info.tdms" in the TDMS file Path Controls
Note1: The "No Header Info.tdms" contains a sinusoid waveform
Note2: The "Has Header Info.tdms" contains a header with file type="Trace Data to TDMS" and file version="2.0"
http://forums.lavag.org/index.php?act=attach&type=post&id=5675
http://forums.lavag.org/index.php?act=attach&type=post&id=5677
http://forums.lavag.org/index.php?act=attach&type=post&id=5676
QUOTE(PJM_labview @ Apr 30 2007, 08:21 PM)
Yep, that's a known issue. The door on 8.2.1 closed too early to get the fix in.
http://forums.ni.com/ni/board/message?boar...uireLogin=False
TDMS get Property
LV
Thanks for catching that. I had never seen that one. It seems to crash only if the output is a variant. CAR# 4909S6WJ.
Thanks,
Herbert
QUOTE(Herbert @ May 1 2007, 09:00 AM)
Thanks for pointing to that thread. Unfortunately the described workaround (Check the found output) does not work.
In the example I provided, If you probe the SubVI (Read Data Header from TDMS.vi) found output of the TDMS Get Property, you will see that it return True when reading a TDMS file with no header, meaning in return true when the property does not exist (See Below).
http://forums.lavag.org/index.php?act=attach&type=post&id=5687
...Thanks for catching that. I had never seen that one. It seems to crash only if the output is a variant. CAR# 4909S6WJ.
Thanks for the CAR.
PJM
QUOTE(PJM_labview @ May 1 2007, 02:34 PM)
PJM
:throwpc:
I guess we'll have to get ugly then. "Get Properties" with no property name and no type wired to it will give you a list of all property names. Worst case that can be used to verify whether a property is there or not.
Herbert
