Ronin7 Posted December 8, 2024 Report Posted December 8, 2024 Hello, I recently installed the UI Tools Addon Package and now LabVIEW 2018 crashes immediately on start. I saw a similar topic with the same package where Jim Kring was able to give some instructions privately to help resolve the issue- I would appreciate the same assistance as I have tried to uninstall all packages and reinstall LabVIEW 2018 and LabVIEW still crashes immediately. Appreciate any assistance, Thanks! Quote
Francois Normandin Posted December 8, 2024 Report Posted December 8, 2024 Can you check if you are facing the same problem as in this thread? Quote
Ronin7 Posted December 9, 2024 Author Report Posted December 9, 2024 Yes- that did fix the issue. I moved "Create control.vi" out of the C:\Program Files (x86)\National Instruments\LabVIEW 2018\project\UI Tools\Control Generator directory, opened LabVIEW 2018 SP1 (which now launches without crash), moved "Create Control.vi" back into the original directory and mass compiled the directory and now everything works. I appreciate your assistance and I apologize for digging up an issue with an outdated version of LabVIEW but some of us are stuck on older versions. Again- Thanks! 1 Quote
