Jim Kring Posted May 17, 2007 Report Posted May 17, 2007 Steps to Reproduce 1) Place a Multicolumn Listbox on the Front Panel of a VI http://forums.lavag.org/index.php?act=attach&type=post&id=5876 2) Right-click on the Multicolumn Listbox and choose: Drag and Drop>>Allow Dragging Drag and Drop>>Allow Dropping Both Allow Dragging and Allow Dropping should now be enabled/checked. 3) Initialize the first column and the third column with some data, using the text tool. http://forums.lavag.org/index.php?act=attach&type=post&id=5877 4) Attempt to drag and drop some of the rows to reorder them. Observed Results Note that you can drag and drop only if you mouse-down on the first or third columns (having text). If you mouse down on the second column (with no text) drag and drop does not work. Expected Results I would expect drag and drop to work, as long as I mouse down on any column of a row that has at least one initialized column. http://forums.lavag.org/index.php?act=attach&type=post&id=5878 Another Oddity... Add some text to one of the empty cells. Now, highlight the text you just added and press the delete key. Try to drag and drop the row containing the cell whose text you just deleted by mousing down on that cell. Note that drag and drop now works when mousing down on that cell. However, it does not work when mousing down on any of the other empty cells (the ones that never had any text). From this last oddity, it leads me to believe that I might be able to work around this bug by initializing the empty cells, somehow. Perhase this can be done by writing empty strings to these cells. Quote
Jim Kring Posted May 19, 2007 Author Report Posted May 19, 2007 FYI: We found a work-around, which is to write a string with a single space character to the empty cells. Quote
Jim Kring Posted May 20, 2007 Author Report Posted May 20, 2007 Update... [CAR 49EJT400] Status: Reported to NI R&D Quote
