Get Inside Control
Hi all,
I can't see any way to get the value of a "control" composing an Array, without creating this control.
I explain myself:
I have an Array of listbox. I initialise the property "String []" of this listbox, via a Property node of this control, BUT this control doesn't really exist in my Bloc Diagram! because it is embedded inside the Array.
Now, I would like to get the "String []" of this control via the VI Server.
And as far as I know, it's impossible because the VI Server can't find the listbox control !
Does someone has an idea, how to get this, without creating the listbox as a real control...
Here is my bloc diagram simplified:
http://forums.lavag.org/index.php?act=attach&type=post&id=5999
And the code in 8.2:
http://forums.lavag.org/index.php?act=attach&type=post&id=6000
Thanks for your help!
Laurent
QUOTE(tcplomp @ Jun 1 2007, 03:52 PM)
You have to get inside the array control:
Ton
Thanks Ton!
I wanted in fact String[] from the ring control, which I get (from inside your loop!)
Perfect!
Laurent
