phuzionz Posted June 9, 2007 Report Posted June 9, 2007 I don't understand what the big advantage is of working with an Xcontrol. The Xcontrol gives you some data, like datachange etc....., but what is the reason of that. Thanks Jeroen Quote
Ton Plomp Posted June 9, 2007 Report Posted June 9, 2007 Hi Jeroen, one example. I recently had an application were we wanted to know the 2nd order polynomial fit, but also showing the data as points in an graph, showing the polynomial fit in a graph and showing the fit in a string indicator. Wasn't that hard, but then the custumor wanted 4 of these fits! Copy paste, creating new terminal for everything with very logical names. If I had done an XControl in the first place I only had to copy the XControl terminal. I believe the new mixed signal graph is an XControl+Xnode in one, this shows the strengths and weaknesses of the system. Ton Quote
