alukindo Posted June 10, 2007 Report Posted June 10, 2007 Hi: See the block diagram code snippet below. The front panel result is pasted on the lower right. . . . . . Doesn't this demonstrate a bug for the attribute: <cell justification> when used with the <active row property>? Other formatting attributes seem to work OK. Anthony Quote
Ton Plomp Posted June 10, 2007 Report Posted June 10, 2007 QUOTE(alukindo @ Jun 9 2007, 02:20 AM) Hi:See the block diagram code snippet below. The front panel result is pasted on the lower right. . . . . . Doesn't this demonstrate a bug for the attribute: <cell justification> when used with the <active row property>? Other formatting attributes seem to work OK. Anthony I assume this is in 7.1.1, could you post the VI so we can test if this is fixed? Ton Quote
alukindo Posted June 10, 2007 Author Report Posted June 10, 2007 QUOTE(tcplomp @ Jun 9 2007, 01:24 PM) I assume this is in 7.1.1, could you post the VI so we can test if this is fixed?Ton tcplomp: The code pasted is from LabVIEW 8.2.1 Anthony Quote
Ton Plomp Posted June 10, 2007 Report Posted June 10, 2007 QUOTE(alukindo @ Jun 9 2007, 09:51 PM) tcplomp:The code pasted is from LabVIEW 8.2.1 Anthony Thanks, since your post didn't include a version reference I was looking at the version mentioned in your profile (please update). Since it's a bug in the current version please inform NI, via your local representative or via the web. Ton Quote
Mike Ashe Posted June 12, 2007 Report Posted June 12, 2007 From one point of view, this is more of a documentation issue than a bug. The justification seems to work for the entire column. If you place a delay in the loop, you can see it cycle through the various justifications and whatever is last is the one you end up with. Then again, a bug is usually defined as any undesired behavior. If it says "Row" I'd like to see it work for each Row, not just change the doc's to reflect actual behavior. The Multi Column List Box works correctly, allowing you to set justification on a per cell basis. Quote
