Phil Duncan Posted June 13, 2007 Report Posted June 13, 2007 Hi all, I have been working on an application that I recently improved by implementing a timed loop and timed sequence structure. The VI's work fine in the LV environment but the compiled application tells me it can't find several of the timed structure controls. Namely the wakeup.ctl, nitl_modes.ctl and the timing_clust.ctl. I pointed the dialog box to the appropriate ctl's in the LV directory and the app then gave me the following errors. The program was developed with the LV professional dev suite. http://forums.lavag.org/index.php?act=attach&type=post&id=6073 I am at a loss as to why the app thinks I don't have the full dev version and secondly why the app builder hasn't included the required files? :headbang: Cheers & Beers :thumbup: :beer: Quote
LAVA 1.0 Content Posted June 14, 2007 Report Posted June 14, 2007 I don't know if your problem is the same as mine was, but I couldn't use LabVIEW 8.0.1 with timed loops that used Digital Change Detection. See here... http://forums.ni.com/ni/board/message?boar...e.id=6287#M6287 I loaded and built my app with 8.2 and it worked as it should have..... Quote
Phil Duncan Posted June 14, 2007 Author Report Posted June 14, 2007 QUOTE(LV Punk @ Jun 13 2007, 10:07 AM) I don't know if your problem is the same as mine was, but I couldn't use LabVIEW 8.0.1 with timed loops that used Digital Change Detection. See here... http://forums.ni.com/ni/board/message?board.id=70&message.id=6287#M6287' target="_blank">http://forums.ni.com/ni/board/message?boar...e.id=6287#M6287I loaded and built my app with 8.2 and it worked as it should have..... Thanks for the info. My app is performing several DAQmx functions within the timed structures however it has been developed in LV 8.2. I will keep trying to nut this one out. Cheers & Beers :thumbup: :beer: Quote
Phil Duncan Posted June 14, 2007 Author Report Posted June 14, 2007 Problem solved. I simply selected the option "... do not disconnect type definitions or remove ..." Cheers & Beers :thumbup: :beer: Quote
