Rician Distribution
AA ... simply the problem is that i need to generate a random Signal [Noise] with Rician Distribution or even Rayleigh Distn. which are used in radar application. i searched in the labview for this Rician but nothing i could get.
Do you have any ideas about how to Generate siganl with Rician Distn.??!!
Thnx in advance
Sherif Farouk (",)
QUOTE(Karissap @ Jun 18 2007, 06:20 AM)
Hi Sherif
The NI Modulation toolkit offers Rayleigh or Rician Distribution fading VIs.
Here is an extract from the NI modulation toolkit datasheet:
http://forums.lavag.org/index.php?act=attach&type=post&id=6123
Here is an example in MATLAB if you want to look at the algorithm and implement it yourself in LabVIEW, you might even be able use most of it in a math script node.
Thank you Karissap .
