Eugen Graf Posted June 21, 2007 Report Posted June 21, 2007 Hello, I want to install only really needed parts on target PC (WinXP). My application uses NI-CAN. I should to install LV-Runtime + NI-CAN, but if I select NI-CAN in installer, I can't unselect MAX, C++-Language Support and so on. I can only install full NI-CAN and all the additional shit will be installed on target PC. Where I can unselect additionals? Thanks, Eugen Quote
Michael Aivaliotis Posted June 25, 2007 Report Posted June 25, 2007 I don't think you have a choice. Quote
Chris Davis Posted June 25, 2007 Report Posted June 25, 2007 QUOTE(Michael_Aivaliotis @ Jun 23 2007, 07:31 PM) Quote I don't think you have a choice. He may or may not have a choice. If you download the NI-CAN installer from NI's website, and unzip it, but not install it you would be able to see all of the MSI packages it installs. This would let you pick out just the NI CAN MSI package. You would then have to provide this MSI file with the installer, and install it manually for the user after your program has installed. This may, or may not work in your situation, since I've never used NI-CAN I can't really say if you have to have MAX for it to be useful. Quote
