Ton Plomp Posted July 5, 2007 Report Posted July 5, 2007 Somehow I expecte the following code to set the VI to be the active window: http://forums.lavag.org/index.php?act=attach&type=post&id=6302 But the Frontpanel is not the active window. I set my Front panel to be floating: http://forums.lavag.org/index.php?act=attach&type=post&id=6303 Does anyone know a solution? This is all in LV 8.2.1, in LV 8.0.1 it works as expected Ton Quote
Wolfram Posted July 5, 2007 Report Posted July 5, 2007 ZITAT(tcplomp @ Jul 4 2007, 08:13 AM) Somehow I expecte the following code to set the VI to be the active window:http://forums.lavag.org/index.php?act=attach&type=post&id=6302 But the Frontpanel is not the active window. I set my Front panel to be floating: http://forums.lavag.org/index.php?act=attach&type=post&id=6303 Does anyone know a solution? This is all in LV 8.2.1, in LV 8.0.1 it works as expected Ton See here: forums.lavag.org/index.php?showtopic=8523&pid=32105&st=0& This might help. Wolfram Quote
