Option to save to multiple file.
Depending on the testing enviroment I want the operator to be able to chose where collected data is stored on a PC hard drive. In the existing logic that I need to modify the file is saved to one .txt file. I'd like to change this to 4-5 that the operator can chose from via a pull-down menu. Any ideas?
As part of the dialog for selecting the test type add a path control and configure it (right click) so that the user selects a folder or a file, depending on what you need.
If you need it to be preselected values, use a ring or a combo box and prepopulate it using a property node. If the path is long, I would advise shortening it for the display.
If this didn't help you, I suggest you provide more details about what you want.
QUOTE(yen @ Jul 5 2007, 01:41 PM)
  Quote
Thank you, I'll give it a shot.
