cRIO 9004 / Host to Target DMA ?
i2dx
Hi Folks,
I'm trying to implement a "Host to Target" (which means: RT to FPGA) DMA Transfer on a cRIO 9004 controler with a 3M-Gate chassis. The FPGA VI compiles without errors, but when I start my RT-VI I get the error -63001, which is explained as "DMA from host to FPGA target is not supported for this platform".
Has anyone made similar experiences or (hopefully) has someone allready successfully implemented a Host to Target DMA on a cRIO 9004 controler?
Thank you,
CB
QUOTE(i2dx @ Jul 5 2007, 09:11 AM)
Hi Folks,
Thank you,
CB
The error message you're seeing is accurate. The 9004 allows DMA transfers only from FPGA to RT, not the other direction. Host to Target DMA is a new feature of the 9012/9014 cRIO controllers and is not supported on the older controllers.
QUOTE(ned @ Jul 5 2007, 04:29 PM)
thank you!
<insert a bunch of heavy insults into the direction of NI here> ;)
