Pandiarajan Posted July 10, 2007 Report Posted July 10, 2007 HI, I am using LV 8.2. In my application, the users are allowed to change the Tags and Descriptions of the tree. So, I want to capture the end of edition of the tree's tag and description to do some internal updation. Now, I am capturing this by asking the user to press enter at the end of edition. Is there any better way to do this? Thanks, Pandiarajan R Quote
Ton Plomp Posted July 10, 2007 Report Posted July 10, 2007 Hi Pandiarajan, I didn't know you could edit 'tags' of a tree. So I need to see the code give a meaningfull answer. Could you post some? Ton Quote
Pandiarajan Posted July 17, 2007 Author Report Posted July 17, 2007 QUOTE(tcplomp @ Jul 9 2007, 03:28 PM) Hi Pandiarajan,I didn't know you could edit 'tags' of a tree. So I need to see the code give a meaningfull answer. Could you post some? Ton Hello Ton, Sorry for the Delay in reply. The tags of the tree can be edited. The attached vi explains that. Thanks, Pandiarajan R Quote
Ton Plomp Posted July 17, 2007 Report Posted July 17, 2007 I'm sorry to disappoint you but you don't edit the tag, just the first string of the table. Add an indicator to the active tag output of the event node Ton Quote
Pandiarajan Posted July 18, 2007 Author Report Posted July 18, 2007 QUOTE(tcplomp @ Jul 16 2007, 05:28 PM) I'm sorry to disappoint you but you don't edit the tag, just the first string of the table.Add an indicator to the active tag output of the event node Ton Ok that's fine. Is there any option to capture the end of editing this display string in the tree ? Thanks, Pandiarajan R Quote
Ton Plomp Posted July 18, 2007 Report Posted July 18, 2007 QUOTE(Pandiarajan @ Jul 17 2007, 06:08 AM) Ok that's fine. Is there any option to capture the end of editing this display string in the tree ?Thanks, Pandiarajan R That's quite easy (and new to me as well), but (at least in 8.2) there's a filter event "Edit Cell?" and a normal event "Edit Cell". These are triggered as soon as the user hit's enter to finish the edit. Ton Quote
