Thinkpad tilt-sensors
I just discovered that my IBM Thinkpad has a 2-axis tilt sensor and probably a 3-axis accelerometer in it. It's part of something called "ThinkVantage", and is used primarily to disable the hard drive when motion gets too extreme.
Has anyone tried to access this information? Sounds like it would be fun to play with.
EDIT: Just found this: http://www.stanford.edu/~bsuter/thinkpad-accelerometer/.
Too bad I've got real work to do...
Gary
QUOTE(Gary Rubin @ Jul 20 2007, 04:35 AM)
Ooooo that's so cool! I've got real work to do, but I might be able to squeeze this one in jusy for its coolness factor ;)
EDIT: Yep, that little exe on the site works like a charm!
QUOTE(crelf @ Jul 19 2007, 02:48 PM)
I've come to expect grand things from you, Chris. When will we see a Code Repository entry for wiring Labview diagrams by changing the orientation of your lap? :P
QUOTE(Gary Rubin @ Jul 20 2007, 04:54 AM)
I'm thinking of something like turning your laptop into an etch-a-sketch... :D
QUOTE(crelf @ Jul 19 2007, 03:04 PM)
I'm not at all familiar with the Mindstorms capabilities... Could you use the laptop as a remote control? Tilt it right, and the robot turns right, tilt it forward and it accelerates, etc.?
QUOTE(Gary Rubin @ Jul 20 2007, 05:07 AM)
How much spare time do you think I have?!?! :rolleyes:
QUOTE(Gary Rubin @ Jul 19 2007, 05:06 PM)
Well, after about 2 minutes of trying, all I've gotten is the roll axis.
oops, wrong datatype. Now I get x and y
QUOTE(Gary Rubin @ Jul 20 2007, 08:29 AM)
Hmmm. I'm running as a local admin. I wonder if that matters.
Me too - once I pointed it explicitly to the file in the Windows\System32 directory, all is well.
QUOTE(crelf @ Jul 19 2007, 07:08 PM)
It appears that there's a z-axis too. Just add a third value to the clusters.
QUOTE(Gary Rubin @ Jul 20 2007, 11:16 AM)
I'd like to, but I don't have the appropriate versions installed - anyone else care ro help out?
Introducing the "Labview - Thinkpad
Theramin
Again, it takes ages to load unless you overtly link the dll to the location, so please don't just put "sensor.dll" in the "Library name or path", put the whole path in there too. Also, it doesn't seem to work with LabVIEW 8.20 - I get sound, but it doesn't change with the tilt in any direction...
QUOTE(crelf @ Jul 20 2007, 07:51 AM)
When I open it on mine, the full path is there.
QUOTE(orko @ Jul 24 2007, 04:11 AM)
Hey, they did this with the phones, why not do it on a laptop? ;)
It's a pity that there isn't a standard API for these sensors for all laptops (is there?) - otherwise, that would make a kick-arse coding challenge...
