Eugen Graf Posted July 21, 2007 Report Share Posted July 21, 2007 Hello, can anybody say me why I get a File Permission Error here? http://forums.lavag.org/index.php?act=attach&type=post&id=6414 I think, I know why. The VI Read From Text File creates a reference to a Read-Only File. So I have either to open file with Read-Write-Permissions at the begin or Have to close the reference after reading. It's right? Eugen So, here is one which works without errors. http://forums.lavag.org/index.php?act=attach&type=post&id=6417 Quote Link to comment
jzoller Posted July 21, 2007 Report Share Posted July 21, 2007 Hi Eugen, I think you are correct, the Read From Text File appears to open files directly in a Read-Only mode. As you said, you can correct this by explicitly opening the file using Open/Create/Replace File with the Read/Write option enabled, then feeding the resulting refnum into the Read From Text File. Not giving the read/write mode option on the Read From Text File primitive seems kinda silly, since the function spits out a refnum. Of course, having hard-to-spot right click options on the primitive seems like a step backwards as well I guess it depends who's using the primitive. Joe Z. Quote Link to comment
