Davide Bugiantella Posted May 29, 2025 Report Posted May 29, 2025 HI. Using LabVIEW 2018 32-bit, I created an application for Windows 10, but random crashes occur with error code 0xc0000005. My suspicions fall on the VIs used to communicate with the Yokogawa WT5000, but after reviewing the various lvlog files, I haven't been able to identify which specific VI is causing the crash. That said, I would kindly ask for your assistance in identifying the VI responsible for the issue. Thank you. 03dc9418-0115-4f24-ba73-07f98ebf6821.zip 3eb1d949-0f35-4147-809b-7f7dff13ad06.zip 6bcc6278-fb26-48c7-a715-ab2f35a336de.zip 6f80126d-b9e2-4a12-b7f2-e8c15fb9ea48.zip Quote
Rolf Kalbermatter Posted May 29, 2025 Report Posted May 29, 2025 As far as I can see on the NI website, the WT5000 instrument driver is not using any DLL or similar external code component. As such it seems rather unlikely that this driver is the actual culprit for your problem. Exception 0xC0000005 is basically an Access Violation fault error. This means the executing code tried to cause the CPU to access an address that the current process has no right to access. While not entirely impossible for LabVIEW to generate such an error itself, it would be highly unlikely. The usual suspects are: - corrupted installation of components such as the NI-VISA driver but even LabVIEW is an option But if your application uses any form of DLL or other external code library that is not part of the standard LabVIEW installation, that is almost certainly (typically with 99% chance) the main suspect. Does your application use any Call Library Node anywhere? Where did you get the according VIs from? Who developed the according DLL that is called? Quote
