Converting data file from TDMS to TXT - time format and headers.
I have this .vi that converts the .TDMS to ASCII. However at the moment the time format is "00:00.000001    5.2041    0.2388    -0.0004    0.9106" for each line.
How can I make it in seconds in scientific format so the data will show as "1e-6    5.2041    0.2388    -0.0004    0.9106"?
Also how can the headers be added into the ASCII file?
to_Asci_2.viFetching info...
  On 6/18/2025 at 2:55 PM, Francois Normandin said:
@sts123 You can explore the String palette where you will find an array of string formatting nodes.
The simplest for you is to replace the date/time string with Format into string, and configure for scientific number.
Expand
I tired using Format into string, but then the result text file includes time stamp 4 times for each line of data, instead of doing just once.
Use Get Waveform Attribute (Waveform>>Get Attribute) to read the NI_ChannelName string attribute from each waveform. Add another loop before the first one where you get it from each waveform and then write it to the file.
DAQmx creates that attribute automatically. This is what Waveform Graphs use for plot names.
Expand
It does not throw the names as expected.
to_Asci_3_range_2.viFetching info...
right-click the node, select "help" and read the manual, please
why use a while loop? use an auto-indexing for loop!
Edited by cordm
