sts123 Posted 4 hours ago Report Posted 4 hours ago I have this .vi that converts the .TDMS to ASCII. However at the moment the time format is "00:00.000001 5.2041 0.2388 -0.0004 0.9106" for each line. How can I make it in seconds in scientific format so the data will show as "1e-6 5.2041 0.2388 -0.0004 0.9106"? Also how can the headers be added into the ASCII file? to_Asci_2.vi Quote
Francois Normandin Posted 2 hours ago Report Posted 2 hours ago @sts123 You can explore the String palette where you will find an array of string formatting nodes. The simplest for you is to replace the date/time string with Format into string, and configure for scientific number. Quote
sts123 Posted 2 hours ago Author Report Posted 2 hours ago 7 minutes ago, Francois Normandin said: @sts123 You can explore the String palette where you will find an array of string formatting nodes. The simplest for you is to replace the date/time string with Format into string, and configure for scientific number. I tired using Format into string, but then the result text file includes time stamp 4 times for each line of data, instead of doing just once. Quote
cordm Posted 1 hour ago Report Posted 1 hour ago If the time appears for each channel, then you didn't set the loop tunnel mode to last value. Quote
