Converting data file from TDMS to TXT - time format and headers.
sts123
I have this .vi that converts the .TDMS to ASCII. However at the moment the time format is "00:00.000001    5.2041    0.2388    -0.0004    0.9106" for each line.
How can I make it in seconds in scientific format so the data will show as "1e-6    5.2041    0.2388    -0.0004    0.9106"?
Also how can the headers be added into the ASCII file?
to_Asci_2.vi
7 minutes ago, Francois Normandin said:
@sts123 You can explore the String palette where you will find an array of string formatting nodes.
The simplest for you is to replace the date/time string with Format into string, and configure for scientific number.
I tired using Format into string, but then the result text file includes time stamp 4 times for each line of data, instead of doing just once.
