kelbro Posted August 16, 2007 Report Posted August 16, 2007 Using LV 7.1, it seems simple enough but I cannot get the correct time to display in the built in graphs (waveform charts). Any suggestions? Thanks! Quote
orko Posted August 16, 2007 Report Posted August 16, 2007 Check out the "Format and Precision" properties of the wafeform chart. In it you can drop down the X-axis and select the time format you want (absolute or relative). Here's an example: http://forums.lavag.org/index.php?act=attach&type=post&id=6634 (LV7.1.1) Quote
kelbro Posted August 17, 2007 Author Report Posted August 17, 2007 QUOTE(orko @ Aug 15 2007, 02:42 PM) Check out the "Format and Precision" properties of the wafeform chart. In it you can drop down the X-axis and select the time format you want (absolute or relative). Here's an example:http://forums.lavag.org/index.php?act=attach&type=post&id=6634''>http://forums.lavag.org/index.php?act=attach&type=post&id=6634'>http://forums.lavag.org/index.php?act=attach&type=post&id=6634 (LV7.1.1) Yes, that is selected yet it defaults to Dec 31 1903 5pm. Quote
orko Posted August 17, 2007 Report Posted August 17, 2007 QUOTE(kelbro @ Aug 15 2007, 04:27 PM) Yes, that is selected yet it defaults to Dec 31 1903 5pm. Sorry, forgot to wire the t0 input to the build waveform. Here's another example: http://forums.lavag.org/index.php?act=attach&type=post&id=6638''>http://forums.lavag.org/index.php?act=attach&type=post&id=6638'>http://forums.lavag.org/index.php?act=attach&type=post&id=6638 Quote
