Seedance 2.5: Show the Idea Before You Build It
emily
Imagine reviewing a sketch of a desktop sorting device with the person who will use it. You expect the block to stop while a gate opens. They expect it to keep moving. The parts are all on the drawing, but describing the sequence reveals a different understanding.
A short concept clip might help make that disagreement visible before the build.
I run the website offering Seedance 2.5. One use I would like to explore is bringing a reference sketch into the generator and describing a single movement. This sorting example is hypothetical; I have not tested it as an engineering workflow.
The question is whether someone can watch the draft and explain the intended behavior back to you.
For this example, I would upload a simple sketch showing the entry point, gate, and tray, then try this prompt:
Use the reference sketch for the layout. A single block approaches the closed gate and stops. After a visible pause, the gate opens fully. Only then does the block move into the tray. Fixed wide view, with the entire path visible. No additional objects.
Before sharing the preview, check whether it follows the sequence and preserves the relevant parts. A block passing through a closed gate or a tray shifting position would change the explanation.
If the action is unclear, revise that instruction in Seedance 2.5 while keeping the reference and viewpoint the same. Check the whole result again, since other details may change too. If revisions keep altering the parts or sequence, use annotated frames for that review.
Once the draft matches the intended movement, show it without talking over it. Ask, “Describe what happens from the moment the block enters the scene.” Listen for whether the viewer notices the stop and the order of events without being prompted.
I would also compare the clip with three annotated frames from the sketch. If possible, show each version to someone who has not seen the other. Do they understand the same sequence? Does motion clarify the pause, or add details that need explaining? The clip needs to earn the extra effort.
Keep “AI-generated concept — timing and mechanics unverified” alongside it. Actual timing, dimensions, clearances, and feasibility still need engineering checks.
For a first attempt, choose a sketch you have permission to upload and one movement people interpret differently. Review that result before expanding the scene.
In an early customer review, what would a generated clip need to show before you would find it useful?
