Possible to set cases based on variables?
I have one variable I need to compare against several other variables in order to choose which case to run. It's easy to do in text languages using ElseIf or Select statements, but I can't figure out if it is possible for Labview case structures to be defined by variables.
Pseudocode[/u]If A<W then [u]
QUOTE(Daklu @ Aug 17 2007, 02:57 PM)
Pseudocode [/u]If A<W then   [u]
The syntax is in the online help for the case structure. In general, wire the variable to the selection terminal (the '?' terminal) and then put the test in the case selector. For numerics:
..1 is anything less than or equal to 1
3..5 is anything between 3 and 5 inclusively
4 is just 4
4.. is anything greater than or equal to 4
default is anything not covered by any case
..1, 3.. is anything less than/equal to 1 or greater than/equal to three.
QUOTE(Daklu @ Aug 17 2007, 12:57 PM)
Pseudocode[/u]If A<W then[u]
Yes this is quite easy to do. If you want to implement precisely what you've written, use the Less Than function from the Comparison pallette and wire its boolean output to the input of your Case Structure.
Sorry for the double post. :wacko: IE choked while I was writing this and unbeknownst to me posted a garbled, incomplete message. See the other post instead.
