RE-triggerable Analogue output PCI-6259
Azazel
Hello All,
I am trying to create a re-triggerable analogue output with a PCI-6259 NI DAQ card. I have read that there are tricks to do this as the M-series cards were not designed for a re-triggerable analogue output, but you can accomplish this task through counters. Does anyone have any experience with this or some example code that could get me started.
Thanks,
Azazel
LV 8.5, windows XP, PCI-6259
  • 2 weeks later...
Hi All-
This article has a good discussion of the counter "trick" required to make retriggerable AI work. There's a link at the bottom to an example program that includes LabVIEW and several text-based examples of how to set this up using NI-DAQmx.
Hopefully this helps-
