jaegen Posted September 7, 2007 Report Posted September 7, 2007 Christina's new post reminded me of a question I had: The Create Accessor dialog automatically uses "Read" and "Write" in the VI names - is there any way to make this default to "Get" and "Set" instead? Jaegen 1 Quote
Justin Goeres Posted September 7, 2007 Report Posted September 7, 2007 QUOTE(jaegen @ Sep 6 2007, 09:19 AM) The Create Accessor dialog automatically uses "Read" and "Write" in the VI names - is there any way to make this default to "Get" and "Set" instead? I had exactly the same thought the first time I used the Create Accessor dialog. Typically I use the Read/Write semantics to refer to some kind of data transfer (to/from instruments, files, maybe even queues, etc.). When I'm just changing the value of a piece of private class data, I think Get/Set. 1 Quote
Robbie Gehbauer Posted September 8, 2007 Report Posted September 8, 2007 Yes, you can change this to Get/Set. I pull those strings from the global CLSUIP_LocalizedStrings.vi. So, you can just change those two strings by opening <labview>\resource\Framework\Providers\LVClassLibrary\NewAccessors\CLSUIP_LocalizedStrings.vi and changing "Read %s.vi" to "Get %s.vi" and "Write %s.vi" to "Set %s.vi". Then don't forget to pop up on each and select Data Operations>>Make Current Value Default. Save and close the VI and you're good to go! You don't even have to restart LabVIEW. And FYI...if you reinstall or have a new installation, you'll have to repeat this procedure. 1 Quote
Justin Goeres Posted September 8, 2007 Report Posted September 8, 2007 QUOTE(Robbie Gehbauer @ Sep 7 2007, 06:54 AM) Yes, you can change this to Get/Set. I pull those strings from the global CLSUIP_LocalizedStrings.vi. So, you can just change those two strings by opening <labview>\resource\Framework\Providers\LVClassLibrary\NewAccessors\CLSUIP_LocalizedStrings.vi and changing "Read %s.vi" to "Get %s.vi" and "Write %s.vi" to "Set %s.vi". Then don't forget to pop up on each and select Data Operations>>Make Current Value Default. Save and close the VI and you're good to go! You don't even have to restart LabVIEW. Awesome! :thumbup: Note that you also have to switch the Global to Edit Mode first (Operate >> Change to Edit Mode) before you can do Make Current Value Default. 1 Quote
jaegen Posted September 8, 2007 Author Report Posted September 8, 2007 QUOTE(Robbie Gehbauer @ Sep 7 2007, 06:54 AM) Yes, you can change this to Get/Set. I pull those strings from the global CLSUIP_LocalizedStrings.vi. So, you can just change those two strings by opening <labview>\resource\Framework\Providers\LVClassLibrary\NewAccessors\CLSUIP_LocalizedStrings.vi and changing "Read %s.vi" to "Get %s.vi" and "Write %s.vi" to "Set %s.vi". Then don't forget to pop up on each and select Data Operations>>Make Current Value Default. Save and close the VI and you're good to go! You don't even have to restart LabVIEW.And FYI...if you reinstall or have a new installation, you'll have to repeat this procedure. Fabulous! :worship: Jaegen Quote
