Open and Close Reentrant Vi's By Reference
Hi. I'm trying to open and close a reentrant vi by reference. The attached vi "Delete Test.vi" shows how I open the vi "Message - Show Jumps.vi", which opens just fine. However, when I press the OK button on "Message - Show Jumps.vi" the vi will only stop executing. I also want the front panel to close. If I run this vi on its own (by pressing the Run arrow) and then press the OK button it closes without a problem. Does anyone know how to close the front panel of a reentrant vi that is called by reference? Thank you.
Steve
