EJW Posted September 13, 2007 Report Posted September 13, 2007 Is there a way to open a front panel of a second vi and have it work independently of the main program. Normally when i call another vi, the front panel opens and the main program pauses until the vi is closed and then continues on. I would still like to be able to use the second vi to progmatically change things in the main vi if at all possible. Quote
JDave Posted September 13, 2007 Report Posted September 13, 2007 You need to use VI Server. Open a reference to the VI you want to run in parallel, then use the "Run VI" method from an invoke node. Be sure to wire a False to "Wait Until Done". That spawns the VI into a separate process. David EDIT: Looks like there is a Wiki Article that has a little bit of information (mostly what to avoid, not how to implement). Quote
EJW Posted September 13, 2007 Author Report Posted September 13, 2007 QUOTE(dsaunders @ Sep 12 2007, 03:20 PM) You need to use VI Server. Open a reference to the VI you want to run in parallel, then use the "Run VI" method from an invoke node. Be sure to wire a False to "Wait Until Done". That spawns the VI into a separate process.David EDIT: Looks like there is a http://wiki.lavag.org/Invoke_Node' target="_blank">Wiki Article that has a little bit of information (mostly what to avoid, not how to implement). I must be doing something wrong because it wont open the second vi, could you please post a short code example? Thanks. Quote
JDave Posted September 13, 2007 Report Posted September 13, 2007 QUOTE(EJW @ Sep 12 2007, 12:59 PM) I must be doing something wrong because it wont open the second vi, could you please post a short code example? Thanks. It may be that you have the VI set to 'Show When Run' or something like that. Using the 'Run VI' method ignores this setting, so you have to explicitly open the front panel from within the second VI. I will get a little code example together. David Quote
mross Posted September 13, 2007 Report Posted September 13, 2007 QUOTE(EJW @ Sep 12 2007, 03:01 PM) Is there a way to open a front panel of a second vi and have it work independently of the main program. Normally when i call another vi, the front panel opens and the main programpauses until the vi is closed and then continues on. I would still like to be able to use the second vi to progmatically change things in the main vi if at all possible. Take a look at this example I made a while ago to demonstrate what you want. I apologize the paths will be all messed up for you and you will have to browse for the files to get it to run. It is easy to see what is needed. Mike Quote
